CSM:L4 Rejected Connections:
Sep 3rd, 2007
I'm running version 4.2.7.
How can I find out what makes counter L4 Rejected Connections to increase?
Gilles Dufour Tue, 09/04/2007 - 02:03
do a 'show mod csm X tech proc 4'
LB Rjct: rule not match 0
LB Rjct: no real 4843 (2)
LB Rjct: acl denied 0
LB Rjct: no cfg policy 109
LB Rjct: svr init denied 0
LB Rjct: invalid rlid 0
LB Rjct: VIP max-conn 0
LB Rjct: L7 ver mismatched 0
LB Rjct: L7 max parse len 0
LB Rjct: L7 SSL format 0
LB Rjct: L7 parser 0
LB Rjct: no rslt buffer 0
LB Rjct: no lkup buffer 0
LB Rjct: no cookie buffer 0
LB Rjct: no cl NAT port 4087329 (42334)
At the same time, you should also probably get a sniffer trace of csm portchannel.
So you can track a failure.
mruuth Tue, 09/04/2007 - 03:18
Hi Gilles,
My portchannel is loaded with 2*70 Mbps so I need something hook on to create a filter.
