mchandak Tue, 09/04/2007 - 03:56
  • Gold, 750 points or more
By Multiple CallManagers, you are referring to one cluster or multiple clusters ??
If this is one cluster, then yes you can use the same SRST Gateway for multiple servers across the cluster.
Hope this helps
