VPN Client Default Ip pool with discontiguous ip address
Sep 4th, 2007
Hi ,
I just want to know if it's possible to have a default ip pool with discontiguous ip address for vpn client on ASA5520 with 7.2.3.
My customer has a lot of VPN client tunnel group with dedicated ip pool but he want 2 tunnel group to assign ip address from an ip pool, call "pool_default" with ip address from different subnet.
Is it possible or not?
Thanks for yous answers.
aghaznavi Mon, 09/10/2007 - 06:09
Layer 2 loops so even though spanning tree would still be enabled, there is no possibility of a bridging loop. Resiliency depends on EtherChannel, and the topology does not permit NIC teaming from servers without complications because only two access layer switches participate in any VLAN and only one of these is in each data center. Port density can be scaled by adding additional pairs of Layer 2 access layer switches, one of which would reside in each data center. If you add more than two additional Layer 2 access layer switches, the failure of one of the access layer switches could result in a discontiguous subnet
