madhu_mbx Tue, 09/04/2007 - 06:05
Thanks Dharmesh.
Can you please let me know the following?
1. Does Cisco 1131AG series Access Point supports CCX?
2. Is setting up the EAP method, the only change to make it ccx enabled?
3. I would like to capture the Radio measurement messages && beacon frame from the AP. Is this EAP setting will do or should I change any other configuration at the AP?
