Planning to purchase PIX 535
network_team
I want to know is it possible to configure this firewall so that the inside and outside interface are configured on the gigabit port modules rather than on board ?
Does anyone knwo if this is possible or any problems i may run into ?
srue
Level 7
Level 7
you can name any interface 'inside' or 'outside' and assign any security level to any interface.
so yes, it's possible.
Is there any documentation for this, all i know is that i will need to change the security of the interfaces but is there anything else
Tons, you should receive a 'getting started manual' with it, read that and after go to cisco.com, specifically here and go into security, select OS version, blah blah....
http://www.cisco.com/en/US/partner/support/index.html
