09-04-2007 04:19 AM
Our CW LMS 2.6 is integrated with ACS 4.0.
All devices in LMS have been imported from ACS by BlunkImport. But device discovery does not see any device.
DeviceDicovery.log
Unable to open debug file: D:\log\discovery.log
Instead Messages will be now logged to the file in the NMSROOT location: C:\PROGRA~1\CSCOpx\log\discovery.log
MESSAGE DiscoveryMain: Properties will be read from C:\PROGRA~1\CSCOpx\campus\etc\cwsi\DeviceDiscovery.properties
messages will be logged to file: D:\log\discovery.log
discovery.log
2007/09/04 11:00:01 main MESSAGE DiscoveryMain: Properties will be read from C:\PROGRA~1\CSCOpx\campus\etc\cwsi\DiscoveryStatus.properties
2007/09/04 11:00:01 main MESSAGE DBConnection: Created new Database connection [hashCode = 3456720]
Common trust user is: admin
User name in Security context is: admin
log4j:ERROR No appenders could be found for category (CTM.common).
log4j:ERROR Please initialize the log4j system properly.
2007/09/04 11:00:02 main MESSAGE DCRDevWrapper: Fetching DCRDeviceIDs
com.cisco.nm.dcr.DCRException: Authorization Failed
at com.cisco.nm.dcr.LocalDCR.getDeviceIdentifiers(Unknown Source)
at com.cisco.nm.dcr.DCRProxy.getDeviceIdentifiers_DIRECT(Unknown Source)
at com.cisco.nm.dcr.DCRProxy.getDeviceIdentifiers(Unknown Source)
at com.cisco.nm.ani.server.devdiscovery.DCRDevWrapper.getDCRDeviceIDs(DCRDevWrapper.java:488)
at com.cisco.nm.ani.server.devdiscovery.DCRDevWrapper.getDevicesFrmDCR(DCRDevWrapper.java:584)
at com.cisco.nm.ani.server.devdiscovery.DevdiscoverySMFCreateSeedDevice.apply(DevdiscoverySMFCreateSeedDevice.java:98)
at com.cisco.nm.ani.server.framework.EvalSMFApply.apply(EvalSMFApply.java:93)
at com.cisco.nm.ani.server.frontend.EvalGroup.executeMajorNode(EvalGroup.java:578)
at com.cisco.nm.ani.server.frontend.EvalGroup.apply(EvalGroup.java:655)
at com.cisco.nm.ani.server.frontend.EvalGroup.apply(EvalGroup.java:611)
at com.cisco.nm.ani.server.devdiscovery.DiscoveryMain.performScheduleFunction(DiscoveryMain.java:207)
at com.cisco.nm.ani.server.devdiscovery.DiscoveryMain.main(DiscoveryMain.java:51)
2007/09/04 11:00:07 main WARNING DCRDevWrapper: Got DCRException in getDeviceIDs() Authorization Failed
2007/09/04 11:00:07 main WARNING DCRDevWrapper: Zero Devices found in DCR
2007/09/04 11:00:26 EvalTask-Devdiscovery-15 WARNING DevdiscoverySMFGetDeviceType: SNMP unreachable device at: 192.168.20.177 will not remap SMFFactory
2007/09/04 11:01:31 DBConnecton-Reaper MESSAGE DBConnection: Closed Database connection [hashCode = 3456720]
2007/09/04 11:31:38 EvalTask-Devdiscovery-38 WARNING DevdiscoverySMFGetDeviceType: SNMP unreachable device at: 192.168.17.9 will not remap SMFFactory
2007/09/04 11:32:23 EvalTask-Devdiscovery-44 WARNING DevdiscoverySMFGetDeviceType: SNMP unreachable device at: 192.168.17.22 will not remap SMFFactory
2007/09/04 11:32:23 main ERROR DevdiscoverySMFEnd: Error in add Device: Authorization Failed
2007/09/04 11:32:23 main MESSAGE DiscoveryMain: Properties will be read from C:\PROGRA~1\CSCOpx\campus\etc\cwsi\DiscoveryStatus.properties
2007/09/04 11:32:23 main MESSAGE DCRDevWrapper: Closing DCRProxy
2007/09/04 11:32:23 main MESSAGE DBConnection: Created new Database connection [hashCode = 1581629]
Solved! Go to Solution.
09-18-2007 08:02 AM
You should not touch the CiscoWorks Windows services unless explicitly asked to do so by TAC. Under normal operation, those services will work without any user intervention.
09-04-2007 07:45 AM
Given the authorization error, it looks like your System Identity User, admin, is not properly configured in ACS. The System Identity User MUST have all rights to all components in LMS. So check admin's group configuration in ACS, and make sure that each CiscoWorks application is assigned a role with full access rights. This means you will need to createa custom role for each CiscoWorks application (e.g. call in Superuser).
09-17-2007 09:17 PM
It is possible to change the System Identity User on Services menu (Microsoft Windows)?
Can you send me a list of services for each CW component? Can you send me a list (web link) of services for each CW component?
09-17-2007 09:26 PM
No, the System Identity User must be changed within LMS under Common Services > Server > Security > System Identity Setup.
I'm not sure I understand the second question. To which services do you refer?
09-17-2007 09:53 PM
I have thought that it is necessary to replace user under which CM services in Microsoft Windows are started.
09-18-2007 08:02 AM
