Call from unity
Sep 4th, 2007
Set up A
Call comes in on DDI from mobile A,
Call is directed into unity (calling number is altered to 4266)
User presses 1
call is diverted to phone A
CLI presented on Phone A is mobile A
Set up B
Call comes in on DDI from mobile B,
User presses 1
call is diverted to phone B
CLI presented on Phone A is translated called number (4266)
How come on setup 1 I see the CLI for the mobile and in setup 2 I see the CLI of the translated number?
set up 1
CM =4.2
Unity = 4.05
Set up 2
CM = 4.1
Unity 40.3
Is this a version thing?
vmoopeung Mon, 09/10/2007 - 06:35
  • Bronze, 100 points or more
New and Changed Information
This section describes any new features and or changes for CDRs that are pertinent to the specified release of Cisco CallManager.
Cisco CallManager Release 4.2(1)
For this release, you can configure Cisco CallManager to report the directory number (DN) of the hunt group member who answered a direct call to the hunt pilot number in the final called party number field in the CDR. Previously, Cisco CallManger reported the hunt pilot DN in the final called party number field in the CDR.
When you enable the service parameter and set Show Line Group Member DN in the finalCalledPartyNumber CDR field parameter to True, the finalCalledPartyNumber field in the CDR will record the DN of the member who answered the call. When you disable the service parameter and set Show Line Group Member DN in finalCalledPartyNumber CDR field parameter to False, the finalCalledPartyNumber field in the CDR will record the hunt pilot DN. By default, the system sets the Show Line Group Member DN in finalCalledPartyNumber CDR field parameter to False. For example, when a direct call to hunt pilot number of 8600 is routed and picked up by hunt group member with extension 2037, the CDR displays the final called party number (finalCalledPartyNumber) as 2037 when Show Line Group Member DN in finalCalledPartyNumber CDR field parameter is set to True. Whereas the CDR displays the final called party number (finalCalledPartyNUmber) as 8600 when Show Line Group Member DN in finalCalledPartyNumber CDR field parameter is set to False.
In addition to the existing voice quality data supported by the SCCP phone, new measurements are added in the new varVQMetrics field. This string field contains voice quality metrics separated by semicolons.
The format of the string is either fieldName=value or fieldName=value/precision.
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_programming_usage_guide09186a00806ed410.html
