Switch Default-Gateway Question
Answered Question
Sep 4th, 2007
How do I observer the default-gateway set on a switch? I am not able to view it with the "show running-config" command.
Correct Answer by glen.grant about 9 years 4 months ago
Use the command "show ip default " , this will list the gateway on all layer 2 switches and any layer 3 switch that has routing turned off .
Correct Answer by dominic.caron about 9 years 4 months ago
You should fing "ip default-gateway" in the config.
you can also have a IP route 0.0.0.0 0.0.0.0 entry if ip routing is enable.
The last possibility, (if the switch is working and no default gateway configure), is that the router is doing proxy-arp. This is a security issue but still possible.
Correct Answer by mahmoodmkl about 9 years 4 months ago
show running-config should list it.Check weather it is configured in the switch.
Btw what kind of this switch is.
Mahmood
Overall Rating: 5 (3 ratings)
Correct Answer
mahmoodmkl Tue, 09/04/2007 - 04:51
Mahmood
Correct Answer
dominic.caron Tue, 09/04/2007 - 05:53
Correct Answer
glen.grant Tue, 09/04/2007 - 07:03
rayroyaleverest Tue, 09/04/2007 - 08:53
The command "show ip" lists the switch ip address, subnet mask, and default gateway.
