Restoring a Running Config
Answered Question
Sep 4th, 2007
1. I have a CICSCO 877W router. How do I restore a running config from a different 877W so it completely totally overwites config from my existing config.
2. If I do so will it ask me for the username and password from the restored config file ?
Correct Answer by royalblues about 9 years 6 months ago
1. copy the running config to a text editor such as notepad
2. Paste this config on the privilege console on the other router.
3. save the configs
Once you have configs restored, it will ask for the new credentials as in the restored file.
Are you by any chance trying to reset the password? If yes then the above procedure will not help as you need to be in the privilege mode for doing this which means you are required to authenticate on the router.
you need to do a password recovery on the router to reset the passowrd
HTH, rate if it does
Narayan
Overall Rating: 5 (1 ratings)
Correct Answer
royalblues Tue, 09/04/2007 - 04:58
  • Green, 3000 points or more
3. save the configs
Narayan
purohit_810 Tue, 09/04/2007 - 05:12
  • Silver, 250 points or more
Yes, you shouls know username and password to get running config backup..
1) Copy run tftp (Start TFTP on one Machine)- backup
2) Copy tftp start (For an another device)- Restore
Dharmesh Purohit
