LMS 2.6 support Cisco ACE Application Control Engine Module
Sep 4th, 2007
Any idea when LMS 2.6 starts support Cisco ACE Application Control Engine Module. Now looks like it that i cant fetc config from that module. Also DFM cant manage that module.
Juha
Joe Clarke Tue, 09/04/2007 - 08:03
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
ACE support for LMS 3.6 and 3.0 was only added in the latest round of device updates (in June and July). You will need to download the 2.0.9 Service Pack to get ACE support for DFM.
u346874_2 Tue, 09/04/2007 - 22:48
My dfm version is 2.0.9 but still device discovery says UNKNOWN for ACE? I tryed to do rediscovery but same thing. Any idea what try next.
Juha
Joe Clarke Tue, 09/04/2007 - 23:01
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
What is the sysObjectID of the device?
u346874_2 Tue, 09/04/2007 - 23:05
This is second row from snmpwalk. Is that what you mean.
.iso.3.6.1.2.1.1.2.0 = OID: .iso.3.6.1.4.1.9.1.730
juha
Joe Clarke Wed, 09/05/2007 - 06:15
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Support for the ACE as a standalone device is not present. It can only be managed through the switch.
u346874_2 Fri, 01/25/2008 - 06:30
Does that mean that it is not bossible to get backup from ACE's config itself. ACE boys starts again ask me is it possible. All context are needed to back up.
Juha
Joe Clarke Fri, 01/25/2008 - 10:04
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
No, config and software management operations are not supported for this module in RME. It is only supported for inventory collection.
u346874_2 Tue, 02/12/2008 - 22:23
Is that config backup possible later versions of RME.
thanks
Juha
Joe Clarke Tue, 02/12/2008 - 22:37
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
No, config management is not supported in any version of RME.
