New Bugtoolkit - How to find the ACE?
Sep 4th, 2007
  • Bronze, 100 points or more
Can someone enlighten me in the technique on how to browse the current ACE Bugs in the new Bugtoolkit?
The example for the FWSM doesn't work out on the ACE. :)
Roble
Gilles Dufour Tue, 09/04/2007 - 06:07
  • Cisco Employee,
select version 3.0 for ACE.
But I only saw 1 bug.
Not sure what to expect with this tool since I don't personally use it.
Gilles.
Roble Mumin Tue, 09/04/2007 - 11:34
Does the old and the new Bug Toolkit use the same Database so it is just a "front end" change? I had the feeling that Cisco encourages to use the new toolkit if you want to be up to date.
And regarding your selection CAT6K -> All Version -> 3.0 i don't get ACE Bugs at all.
There should be a LOT more than one or even no Bug so my last source of information left is release notes for 1.5a.
Actually i am looking for a Bug similiar to "CSCsh84238".
Allthough i use 1.5a i still have similiar behavior for redirects after ssl termination. And it is a lot more than 10% as stated in the bug.
CSCsh84238 can only be found in the new toolkit btw. :)
Roble
Gilles Dufour Wed, 09/05/2007 - 01:27
  • Cisco Employee,
1.5a is pretty new, so if you see this type of issue, just open a service request so that the TAC can escalate the issue to us.
Gilles.
