Auto QOS error message Cisco 3825 router with HWIC-D-9ESW
Sep 4th, 2007
On a Cisco 3825 router with HWIC-D-9ESW
Receive the following error message after command auto qos voip trust
Router(config)#interface FastEthernet0/1/0
Router(config-if)#auto qos voip trust
%Error: FastEthernet0/1/0 Service Policy Configuration Failed.Only IN Direction Supported
I am using the following IOS
c3825-ipvoice_ivs-mz.124-11.XJ1.bin
owillins Mon, 09/10/2007 - 11:15
Can you verify that you are not applying auto-qos on a multilink and verify that you have mls-qos enable, make sure on your etherswitch card you don't have any trunk configuration.
jpsandberg Tue, 09/11/2007 - 08:40
I am not applying auto-qos on a multilink.
I do not have any trunk configuration on my etherswitch card.
As to do I have mls-qos enable.
I believe I do.
However I do not find a command to enable mls-qos
Still receiving following error
AutoQoS Error: the following command was not properly applied:
service-policy output AutoQoS-Policy-Trust
I have attached the entire config
