ACS Backup files
Sep 4th, 2007
I have a backup file for acs 3.2.
The server died and the only CD I have is 3.3.3.
Tried to install 3.3.3 but the backup file wont import.
Is there any way to convert the file ?
Jagdeep Gambhir Tue, 09/04/2007 - 06:58
  • Red, 2250 points or more
The only way to convert it is by using same software 3.2. You need to install it on server with 3.2 ver and then upgrade it to 3.3.3.
If you can't do it your self, TAC will assist you with it.
Regards.
~JG
