09-04-2007 07:41 AM - edited 03-11-2019 04:06 AM
how do i permit my remote vpn client to access my router that is situated on the outside interface.
i have this setup:
lan--firewall--router--internet
i was able to let the remote vpn client access resource on my DMZ. Now, i also need to allow it to access my router on one of its outside interface.
below is a sample config:
interface Ethernet0/0
nameif outside_bayantel
security-level 0
ip address 121.97.xx.xx 255.255.255.248
interface Ethernet0/1
nameif inside_lan_data
security-level 100
ip address 192.168.100.1 255.255.255.0
interface Ethernet0/2
nameif DMZ_to_Voice
security-level 50
ip address 192.168.200.1 255.255.255.0
interface Ethernet0/3
nameif outside_PLDT
security-level 0
ip address 192.168.50.2 255.255.255.0
access-list inside_lan_data_nat0_outbound extended permit ip 192.168.100.0 255.255.255.0 192.168.100.168 255.255.255.248
access-list outside_PLDT_nat0_outbound extended permit ip 192.168.50.0 255.255.255.0 192.168.100.168 255.255.255.248
access-list DMZ_to_Voice_nat0_outbound extended permit ip 192.168.200.0 255.255.255.0 192.168.100.168 255.255.255.248
access-list ccbslan_splitTunnelAcl standard permit 192.168.100.0 255.255.255.0
access-list ccbslan_splitTunnelAcl standard permit host 192.168.200.2
access-list ccbslan_splitTunnelAcl standard permit host 192.168.50.1
ip local pool ccbslan_pool 192.168.100.170-192.168.100.175
global (outside_bayantel) 101 interface
global (outside_PLDT) 101 interface
nat (inside_lan_data) 0 access-list inside_lan_data_nat0_outbound
nat (inside_lan_data) 101 192.168.100.0 255.255.255.0
nat (DMZ_to_Voice) 0 access-list DMZ_to_Voice_nat0_outbound
nat (DMZ_to_Voice) 101 192.168.200.0 255.255.255.0
nat (outside_PLDT) 0 access-list outside_PLDT_nat0_outbound outside
static (DMZ_to_Voice,outside_bayantel) 121.97.xx.xx 192.168.200.2 netmask 255.255.255.255
static (inside_lan_data,DMZ_to_Voice) 192.168.100.2 192.168.100.2 netmask 255.255.255.255
static (inside_lan_data,DMZ_to_Voice) 192.168.100.99 192.168.100.99 netmask 255.255.255.255
static (inside_lan_data,DMZ_to_Voice) 192.168.100.13 192.168.100.13 netmask 255.255.255.255
access-group outside_bayantel_access_in in interface outside_bayantel
access-group outside_PLDT_access_in in interface outside_PLDT
route outside_bayantel 0.0.0.0 0.0.0.0 121.97.79.25 1 track 1
route outside_PLDT 0.0.0.0 0.0.0.0 192.168.50.1 254
group-policy ccbslan internal
group-policy ccbslan attributes
dns-server value 192.168.100.3 4.2.2.2
vpn-tunnel-protocol IPSec
split-tunnel-policy tunnelspecified
split-tunnel-network-list value ccbslan_splitTunnelAcl
how do i allow the remote vpn client to access my router at 192.168.50.1?
09-04-2007 07:50 AM
You may have to allow same security level interfaces to communicate.
same-security-traffic permit inter-interface
09-04-2007 09:58 AM
i've done that but still i cannot communicate to my router at Ethernet0/3.
are this NAT exempt configuration correct?
09-04-2007 11:22 AM
Not sure if you need the outside keyword on the end, but other than that it looks okay.
Does this router have a route to the vpn client subnet?
09-04-2007 12:21 PM
no, the router does not have any route to the vpn client subnet. do i need to add?
09-04-2007 12:22 PM
The router would need to know how to get to the 192.168.100.168 255.255.255.248 network unless of course it's default route is the ASA.
09-04-2007 02:25 PM
thanks bro... finally I'm able to connect to the router from my remote vpn client.
