Tagging internal routes with community
I am trying to set up community based filtering and I cannot seem to be able to tag our own routes with community.
Configuration is:
router bgp 65000
bgp router-id 10.0.0.1
bgp log-neighbor-changes
neighbor 10.0.0.2 remote-as 65001
neighbor 192.168.1.1 remote-as 65002
address-family ipv4
redistribute static
neighbor 10.0.0.2 activate
neighbor 10.0.0.2 route-map CLIENT-IN in
neighbor 10.0.0.2 route-map CLIENT-OUT out
neighbor 192.168.1.1 activate
neighbor 192.168.1.1 remove-private-as
neighbor 192.168.1.1 route-map TRANSIT-IN in
neighbor 192.168.1.1 route-map TRANSIT-OUT out
no auto-summary
no synchronization
network 10.0.0.0 mask 255.255.255.0
network 100.0.0.0 mask 255.255.255.0
exit-address-family
ip classless
ip route 10.0.0.0 255.255.255.0 Null0 255
ip route 100.0.0.0 255.255.255.0 Null0 255
ip bgp-community new-format
ip community-list expanded CLIENT-OUT permit 65000:220
ip community-list expanded CLIENT-OUT permit 65000:200
ip community-list expanded CLIENT-OUT permit 65000:180
ip community-list expanded CLIENT-OUT permit 65000:100
ip community-list expanded TRANSIT-OUT permit 65000:220
ip community-list expanded TRANSIT-OUT permit 65000:100
ip prefix-list OUR-NET seq 5 permit 10.0.0.0/24
ip prefix-list OUR-NET seq 10 permit 100.0.0.0/24
route-map TRANSIT-OUT permit 10
match community TRANSIT-OUT
route-map CLIENT-IN permit 10
set local-preference 120
set community 65000:220
route-map TRANSIT-IN permit 10
set local-preference 80
set community 65000:180
route-map CLIENT-OUT permit 10
match community CLIENT-OUT
route-map OUR-NET permit 10
match ip address prefix-list OUR-NET
set community 65000:100
The client gets routes from our upstream and upstream gets routes from our client but nobody gets our routes.
Is there something wrong in this configuration when tagging our own routes and advertising them to our upstream and client?
Thanks in advance!
Overall Rating: 5 (1 ratings)
Edison Ortiz Tue, 09/04/2007 - 09:13
Per your config:
a) you are announcing your static routes via redistribution. Do you see those static routes on this router BGP table ?
b) you have
and CLIENT-OUT is
Well, routes leaving your router aren't tagged yet. Tags are applied as they are sent to the BGP peer or as they come into your router. Your neighbor will see the tag (after adding the send-community option). You are only able to see the tags as they come into your router.
You have nothing to match as they exit, I believe you want to apply the tag as they exit .
The same idea applies to TRANSIT-OUT.
If you do a show ip bgp [ip address] on one of those routes you want to advertise, do you see a tag ? Were those routes originated on this router or learned from another BGP peer ?
The redistribute static was an error from my experiments and I removed it.
sh ip bgp 100.0.0.0 says:
BGP routing table entry for 100.0.0.0/24, version 5
Paths: (1 available, best #1, table Default-IP-Routing-Table)
Flag: 0x820
Not advertised to any peer
Local
0.0.0.0 from 0.0.0.0 (10.0.0.1)
Origin IGP, metric 0, localpref 100, weight 32768, valid, sourced, local, best
R3#
I want to allow our routes to be advertised to upstreams and our customers. I tried to tag them with community 65000:100 and then I added
the community to TRANSIT-OUT and CLIENT-OUT
community lists
Edison Ortiz Tue, 09/04/2007 - 09:28
Ok, I reviewed your config a bit more carefully and now I believe I understand your logic
a) You have 192.168.1.1 and 10.0.0.2 neighbors and you are acting as a transit router.
b) routes coming from 192.168.1.1 are tagged with 65000:180
c) routes coming from 10.0.0.2 are tagged 65000:220
d) You have announce back to 192.168.1.1 routes learned from 10.0.0.2 with a match statement, and opposite direction.
However, you aren't matching your static routes in the advertisement. The route-map filters this advertisement.
You need to add the OUR-NET prefix-list on each OUT route-map.
Ex,
Edison Ortiz Tue, 09/04/2007 - 11:06
Routes are tagged as they enter/exit your router. You can't tag your own routes for internal processing. You need to match based on prefix-lists.
