ASA WebVPN/SSL Client Licensing
Answered Question
Sep 4th, 2007
Does the licensing for the SSL client on the ASA require a key to be installed? We have 5 remote sites all using an ASA5510 and requiring a small number of WebVPN connections (some more then others). What I want to know is can I buy the 100 user license and divide those users among the 5 ASAs as required? or will I need to buy five separate licenses?
Correct Answer by cnienhuis about 9 years 4 months ago
You can't split a single 100 user license. You get 2 with the base license and then you can get 10,25,50 and 100, 250 license increments per device according to Cisco.
Overall Rating: 4 (1 ratings)
Correct Answer
cnienhuis Thu, 09/06/2007 - 17:37
