CCM 4.1, 42,4.3
Sep 4th, 2007
I am still recommending my new customers to purchase Call Manager 4.1(3) if they are not sure whether to move towards Linux Based Call Manager or not in the future. If a client doesn't want Linux based Call Manager down the road then would it be a good idea to go with either Call Manager 4.2 or 4.3?
I heard that only up to CCM 4.1(3) allows the easy migration path toward Linux Based CCM such as 5.1/6.0.
Rob Huffman Tue, 09/04/2007 - 13:17
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Abbas,
From 4.2 there is a direct upgrade path to 6.x which is very good, but not to 5.x as you have noted;
Cisco CallManager Upgrade Paths
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a008086cc7c.shtml
System Requirements
Make sure that you install and configure Cisco Unified Communications Manager Release 6.0(1x) on a Cisco Media Convergence Server (MCS).
You may also install Cisco Unified Communications Manager on a Cisco-approved HP server configuration or a Cisco-approved IBM server configuration.
Cisco Unified Communications Manager requires a minimum of the following items on the Cisco MCS.
2 GB of memory
72 GB disk drive
2 GHz processor
Supported Platforms
To find which servers support the Cisco Unified Communications Manager Release 6.0(1x), refer to the Cisco Unified Communications Manager Server Support Matrix at;
http://www.cisco.com/en/US/partner/products/hw/voiceapp/ps378/prod_brochure_list.html
and
http://www.cisco.com/en/US/customer/products/hw/voiceapp/ps378/prod_brochure0900aecd8062a4f9.html
From these CCM 6.0.(1a) Release notes
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/rel_notes/6_0_1/601acmrn_2.html#wp42710
Hope this helps!
Rob
