CSS11501S-C-K9 Active-Standby
Sep 4th, 2007
i have 2 CSS boxes, is it possible to configure them on the Active-Stanby mode using the Box-to-Box mode ??
im confused because on the Data sheet it's written that only Active-Active
http://www.cisco.com/en/US/products/hw/contnetw/ps792/products_data_sheet0900aecd800f851e.html
please advice...
Hasan
Syed Iftekhar Ahmed Tue, 09/04/2007 - 13:57
  • Blue, 1500 points or more
Box to Box mode is an Active/standby configuration.
For active-active Virtual interface redundancy is used (Where CSS serves as master of one virtual router and backup to a differnt VR)
Box to Box Redundancy
When to Use:
?When Active/Standby is the expected behavior.
?When a dedicated 10/100 link can be configured link between the CSS?s
?When Configuration-Synchronization is needed
When not to use:
?When Active/Active is needed
?When a dedicated 10/100 link between CSS?s cannot be used.
?Lack of 10/100 ports, or the switches are too far apart.
Hope it helps
Syed Iftekhar Ahmed
hassan_oudeh Tue, 09/04/2007 - 14:04
Thanks Syed for the reply,
but my question is the Content Switch model CSS11501S-C support Active-Standby ?
I worked on CSS11506 and i have configured two boxes with Active-Standby but for this one i'm confused because if you check the data sheet you will find that ..
Hasan Mohammad
Syed Iftekhar Ahmed Tue, 09/04/2007 - 14:39
Hassan~
As per my understanding CSS11501S-C is only different then 11501 in the terms that it supports ssl termination and Http compression.
The data sheet you mentioned doesn't mention ACtive/Standby for even 11503 & 11506. I can guarantee you that host to host in supported on 11503 and 11506.
I have not worked on CSS11501S-C specifically but I think it should support Box to Box Active/standby redundancy.
Syed Iftekhar Ahmed
hassan_oudeh Wed, 09/05/2007 - 00:00
Iftekhar,
please check the attached picture that i captured from the data sheet...
what did they mean by the redundancy feature mentioned on the table ?
Hasan Odeh
