Database subsystem - CRS 4.x
Amine-K
I have a couple of questions :
1- When we add a new DSN in the database subsystem we are able to specify the maximum number of connections allowed to connect to that database. Is there any limit to that number? What is the maximum number we can specify for this parameter?
2- In the DB Read Step, can we use 'join' queries (i.e : SELECT table1.id, table2.num FROM table1, table2 WHERE (id=X AND num=Y))
Thanks a lot..
sadbulali
Level 4
Level 4
create a user account that matches the user ID and password on the Cisco CallManager server. Ideally, this change makes a connection is possible.
For related information, refer to these documents:
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a00801d71c5.shtml#
