L3 sw and routers' routing
hi! I'm connecting a L3 3550sw to a L2 29xx sw, and 2 routers are connected to the 29xx sw. I'm doing some testing on routing between a L3 switch with the routers, but i'm not able to propagate the routing table between the L3 switch and the routers. I've attached config of the L3, L2 and one of the routers "sh run" output. Please advise. Thanks.
Overall Rating: 5 (1 ratings)
Edison Ortiz Tue, 09/04/2007 - 17:07
  • Hall of Fame,
    Founding Member
a) The router has LAN IP 172.16.30.5/24
b) The 29xx Switch has access vlan 1 for this router. It has a trunk to the 3550 switch.
c) The switch has IP 172.16.1.1/24 under Vlan1.
These 2 devices can't be RIP neighbors since they are part of a different subnets. You must swap the IP addresses from Vlan30 (172.16.30.1/24) and Vlan1 (172.16.1.1/24)
HTH,
Edit: Or better yet, you can change the access vlan on port 7 and 8 at the 29xx Switch to Vlan30.
Edison Ortiz Wed, 09/05/2007 - 04:29
  • Hall of Fame,
    Founding Member
No, just enter:
switchport access vlan 30
Note.- you only posted one router. I'm assuming the other router also has .30 in the 3rd octet.
