2511 ROM question
Answered Question
Sep 4th, 2007
I read that I might need to upgrade my ROM in order for my router to support 16 Megs of flash. My router currently has 8 flash/16 dram. I am looking for an IOS image that will support the technologies I will encounter on the BSCI test. At the very least I would like to do eigrp, ospf and bgp with IP4. Can anyone suggest an IOS image that will support those features with my current HW? If not, can you tell me how to verify what version of rom I have on my router and if that rom needs to be upgraded for me to buy more flash?
Thank you very much!
Correct Answer by Joseph W. Doherty about 9 years 10 months ago
I haven't doubled checked this, but the older IP only images often supported the major routing protocols. IP only images for a 2500 that will run with 8 MB flash/RAM are:
c2500-i-l.120-28d.bin 6 8 25-AUG-2005
c2500-i-l.121-27b.bin 8 8 24-AUG-2005
Overall Rating: 5 (1 ratings)
cventicinque Wed, 09/05/2007 - 06:30
Still looking for some help here if anyone would be so kind...
Correct Answer
Joseph W. Doherty Wed, 09/05/2007 - 07:14
cventicinque Wed, 09/05/2007 - 08:27
Thank You Very Much.
I noticed that when I was looking for images, some say access server and some say IP or IP Plus. With my setup, I wish to use the 2511 as both an access server and a router that participates in my labs, is that possible. Will one image allow routing only while another image allows access server functionality only?
Thanks again!
Joseph W. Doherty Wed, 09/05/2007 - 14:44
"Will one image allow routing only while another image allows access server functionality only? "
Looks that way, at least for the access version.
The 12.3 plus version adds features, such as DLSw+, IPv6, FRF.12, etc., and gives up very little such as WCCP.
The remote access feature set, if I remember correctly, was designed to support dial-up, async and ISDN. It gives up many features including routing features like BGP and OSPF but provides features like AppleTalk, IPX and Multichassis MultiLink PPP (MMP).
cventicinque Wed, 09/05/2007 - 15:39
Ok, I was confusing access server with reverse telnet. I upgraded to one of the images you recommended and all is good. I will take a crack at 12.3 when I get my flash upgrade.
Thanks for all of your help! :)
