FWSM and ASDM
didyap Mon, 09/10/2007 - 14:03
  • Silver, 250 points or more
After creating the ACL's have you checked if they are working fine and saved this configuration? If you are using ASDM to configure ACL's make sure that it is properly getting configured and that ASDM is not getting hanged in between. For a fix of the problem you should upgrade to the latest ASDM version.
