RME Netconfig job - 2500's / 2600's
Sep 4th, 2007
Hi all,
trying to update an ACL and make a daylight savings change to some routers. The 2500 and 2600's are failing with the following:
Protocol ==>
Message: ERROR:RME_CDL1031:
Transport session to device failed
TFTP: Failed on the device.
Failed to detect SSH version running on the device.
Telnet and SNMP RO are good to the device from RME.
Are these device types supported in RME in terms of Netconfig?
thanks,
Marty.
Joe Clarke Tue, 09/04/2007 - 22:35
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
The devices are supported. You should pick one failing device, start a sniffer trace filtering on all traffic to that device, then re-execute your job. The trace should present a clearer picture as to why the transport protocols are failing.
