Can I have two seperate connections to an ASA 5520 from two different switches in the same DMZ. Will both these link work in an ACTIVE/ACTIVE mode. Kindly Advise.
You can configure two interfaces on ASA in the same DMZ and enable communication between them using the command "same-security-traffic permit inter-interface". Both of the links will be in active state.
