why does not the radius server receive the attribute [8] packet ?
Sep 5th, 2007
hi,all
The Radius Server can't get the attribute [8] packet all the same after I used the command of "radius-server attribute 8 include-in-access-req" in global mode of router.many thanks.
Respects,
Minquan
Overall Rating: 5 (1 ratings)
rochopra Wed, 09/05/2007 - 00:28
  • Cisco Employee,
what is the IOS version you are running ?
If you need this attribute in accounting request try :
aaa accounting delay-start all
~Rohit
guominquan Wed, 09/05/2007 - 00:39
hi,rochopra
The IOS ver:c7200p-ipbase-mz.124-4.XD7.bin
aaa authentication ppp default local
aaa authentication ppp vpdn group radius
aaa authorization network vpdn group radius
aaa accounting network default start-stop group radius
radius-server host 10.10.10.53 auth-port 1812 acct-port 1813
radius-server key gbok00lns
These are several commands configured for Router as above,please refer to them,thanks!
in addition,could you explain this command of aaa accounting delay-start all.
Respects,
Minquan
Premdeep Banga Sat, 09/08/2007 - 09:05
  • Gold, 750 points or more
This might help diagnosing the issue,
debug ppp authen
debug aaa authen
debug aaa author
debug radius
term mon
-aaa accounting delay-start...
Above command means that until the end client has received an IP address, do not send the accounting packet to the accounting server. Once it has, include the IP address handed out, and send the accounting information to the Accounting server.
Prem
