ip nat extendable keyword
Sep 5th, 2007
Hi all
if I use port forwarding on my router, what will happen when if I don't and do use the extendable keyword on the end of the statement ?
spremkumar Wed, 09/05/2007 - 19:22
Hi Carl
hope this helps...
? "Extendable" static translations:
The extendable keyword allows the user to configure several ambiguous static translations, where an ambiguous translations are translations with the same local or global address.
ip nat inside source static extendable
Some customers want to use more than one service provider and translate into each provider's address space. You can use route-maps to base the selection of global address pool on output interface as well as an access-list match. Following is an example:
ip nat pool provider1-space ...
ip nat pool provider2-space ...
ip nat inside source route-map provider1-map pool provider1-space
ip nat inside source route-map provider2-map pool provider2-space
route-map provider1-map permit 10
match ip address 1
match interface Serial0/0
route-map provider2-map permit 10
match ip address 1
match interface Serial0/1
Once that is working, they might also want to define static mappings for a particular host using each provider's address space. The software does not allow two static translations with the same local address, though, because it is ambiguous from the inside. The router will accept these static translations and resolve the ambiguity by creating full translations (all addresses and ports) if the static translations are marked as "extendable". For a new outside-to-inside flow, the appropriate static entry will act as a template for a full translation. For a new inside-to-outside flow, the dynamic route-map rules will be used to create a full translation.
