Urgent ACS and Juniper NSM Attribute file problem
Sep 5th, 2007
Hi frined,
my problem we are handling ACS support with a big customer and Juniper team gave me attribute file for NSM server which installed on linux server and want me to add this file to ACS server to authenticate NSM users through ACS and they said there is acs document on cisco website explain the steps to add this file but I could n't find it.
thanks guys
Overall Rating: 5 (4 ratings)
rochopra Wed, 09/05/2007 - 02:39
I created one such file i am attaching the file here, compare it with the attributes you want to include.
following link explains the attributes used in the file:
Following steps can be used to import file in ACS:
Please place this file on a FTP server, and go to System Configuration >
RDBMS Synchronization > Fill in the credentials > Synchronize Now.
If RDBMS Synchronization option is not visible, enable it from Interface
Configuration > Advanced options > check "RDBMS Synchronization" > submit
Once RDBMS Synchronization is successfull Reboot the ACS SE.
Once ACS SE is backup. Create an AAA client entry with RADIUS (Netscreen)
as the protocol. After this go to,
Interface configuration > RADIUS (Netscreen) and enable which ever
attribute we want to be visible.
rochopra Thu, 09/06/2007 - 17:58
File looks good.
Follow the steps above to sync the file to ACS.
omr123456 Sat, 09/08/2007 - 00:33
Dear Rohit
do u mean by fillowing theses steps where I place the attribute file on FTP server and then using RDBMS SYNC to import the file to ACS so that I do nt need to use the command mode to add them to ACS
Premdeep Banga Sat, 09/08/2007 - 08:04
If you have ACS SE(Box that is shipped by Cisco with ACS pre installed), then steps provided by Rohit are the one that you need to follow. And you do not need to do anything from Command Line on ACS SE.
In case you have ACS for Windows. A software package, that is installed on Windows server platform, then there's another way to do this, using csutil.exe utility.
If you could provide with the original VSA file/Dictionary file/.ini file. We can take a look into it.
omr123456 Sat, 09/08/2007 - 23:18
thanks for help
whaht I have ACS 3.3.3 for windows 2000 platform the file that the customer provided me is attached here it was .txt file I tranfered to .ini file
