BLF not working
Sep 5th, 2007
We have CM 5.0 When we configure the phone button templete and bury it to 7961, it doesn't work. When the configured numbers are busy, the BLF signal doesn't light up. Is there any trick?
Overall Rating: 4 (2 ratings)
shane.orr Wed, 09/05/2007 - 13:20
  • Silver, 250 points or more
I was trying to get BLF working the other day with a 7941 watching the status of a 7940 on call manager 5.1.2 and could not get it to work that day but got busy so I believe I need to know if there is a trick to get it to work as well.
Jon Nelson Wed, 09/05/2007 - 17:23
Assuming that you are using the correct phone template for BLF and the device is configured for BLF, make sure that the SUBSCRIBE CSS is set on the device you are trying to see the BLF on.
Use a common CSS for the SUBSCRIBE CSS or one that will be searchable by all DN's.
Thank you,
Jon
wilsonsant Wed, 01/15/2014 - 05:09
  • " /> Participante em Destaque,
    Prêmio"Escolha dos membros": novembro de 2014
Hi Guys,
I am trying configure BLF in CUCM 8.6.2 and I am having the same problem.
First I created the new phone button template
Then did associate with the speed dial line to BLF
Then Apply the new phone button template and the two DN´s
Then apply css in subscribe both ip phone
then restart two phones, but, didn´t worked
Any have idea about this?
Wilson
Nadeem Ahmed Wed, 01/15/2014 - 05:30
  • Cisco Employee,
Hi Wilson,
Please double check the SUBSCRIBE CSS on the phone page for access to all lines. CM ADMIN--DEVICE--PHONE
That particular CSS needs to reach the partition of the phone being monitored, after that reset the phone
Configuration Checklist for Presence
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/8_5_1/ccmfeat/fsprsnc.html#wpxref
34263
Br,
Nadeem
Please rate all useful post.
wilsonsant Fri, 01/17/2014 - 06:24
Hi Nadeem,
I am sorry by delay in answer, I did the configuration and worked. Thanks a lot for you attentation
Wilson
Nadeem Ahmed Fri, 01/17/2014 - 07:33
  • Cisco Employee,
Np wilson, good to know issue sloved.
Br,
Nadeem
