ASDM issues
Sep 5th, 2007
I have two ASA 5520's running 8.0(2) and ASDM 6.0(2). Ever since I upgraded I've had issues with ASDM when using the Real-Time monitor, it pegs my PC processor at 100% and locks up ASDM. I guess it could be my machine, but I never had an issue with the other versions. Anyone else had similar issues or is there a fix available?
didyap Tue, 09/11/2007 - 07:52
  • Silver, 250 points or more
If you have upgraded the ASDM to ver 6.0.2 and have made no other changes then it seems to be a problem with ASDM. However if you have upgraded from the earlier version and have not made a fresh install of ver 6.0.2, try to do it this time, it may solve the problem.
