Vpn Client disconnecting after a two minutes
Sep 5th, 2007
One user if connects in concentrator 3000 and after two minutes its connection it falls and it appears error 87.
The VPN Client logfile shows:
126 18:21:39.625 08/22/07 Sev=Info/4 IPSEC/0x63700013
Delete internal key with SPI=0x57050f75
127 18:21:39.625 08/22/07 Sev=Info/4 IPSEC/0x6370000C
Key deleted by SPI 0x57050f75
128 18:21:39.625 08/22/07 Sev=Info/4 IPSEC/0x63700013
Delete internal key with SPI=0x3a614e44
129 18:21:39.625 08/22/07 Sev=Info/4 IPSEC/0x6370000C
Key deleted by SPI 0x3a614e44
130 18:21:40.609 08/22/07 Sev=Info/4 IPSEC/0x63700010
Created a new key structure
131 18:21:40.609 08/22/07 Sev=Info/4 IKE/0x63000055
Received a key request from Driver: Local IP = 10.249.7.124, GW IP = 0.0.0.0, Remote IP = 190.44.117.24
132 18:21:40.609 08/22/07 Sev=Warning/3 IKE/0xE3000065
Could not find an IKE SA for 190.44.117.24. KEY_REQ aborted.
133 18:21:40.609 08/22/07 Sev=Warning/2 IKE/0xE3000099
Failed to initiate P2 rekey: Error dectected (Initiate:176)
134 18:21:40.609 08/22/07 Sev=Warning/2 IKE/0xE3000099
Unable to initiate QM (IKE_MAIN:462)
135 18:21:40.609 08/22/07 Sev=Info/4 IKE/0x6300004A
Discarding IKE SA negotiation (I_Cookie=65A7B79BEAEA39AD R_Cookie=5A73CE2626C5DB08) reason = DEL_REASON_PEER_NOT_RESPONDING
136 18:21:40.609 08/22/07 Sev=Info/4 CM/0x63100013
Phase 1 SA deleted cause by DEL_REASON_PEER_NOT_RESPONDING. 0 Crypto Active IKE SA, 0 User Authenticated IKE SA in the system
137 18:21:40.609 08/22/07 Sev=Info/5 CM/0x63100025
Initializing CVPNDrv
138 18:21:40.609 08/22/07 Sev=Info/4 CM/0x6310002D
Resetting TCP connection on port 10000
139 18:21:40.609 08/22/07 Sev=Info/6 CM/0x63100030
Removed local TCP port 3524 for TCP connection.
140 18:21:40.609 08/22/07 Sev=Info/6 CM/0x63100031
Tunnel to headend device 201.40.163.115 disconnected: duration: 0 days 0:1:44
141 18:21:40.609 08/22/07 Sev=Info/4 IKE/0x63000001
IKE received signal to terminate VPN connection
142 18:21:40.625 08/22/07 Sev=Warning/2 CVPND/0xA3400015
Error with call to IpHlpApi.DLL: DeleteIpForwardEntry, error 87
143 18:21:40.625 08/22/07 Sev=Info/6 CM/0x63100037
The routing table was returned to orginal state prior to Virtual Adapter
144 18:21:41.968 08/22/07 Sev=Info/4 CM/0x63100035
The Virtual Adapter was disabled
145 18:21:41.984 08/22/07 Sev=Info/4 IKE/0x63000085
Microsoft IPSec Policy Agent service started successfully
146 18:21:41.984 08/22/07 Sev=Info/6 IPSEC/0x63700022
TCP RST sent to 201.40.163.115, src port 3524, dst port 10000
147 18:21:41.984 08/22/07 Sev=Info/4 IPSEC/0x63700013
Delete internal key with SPI=0x00000000
148 18:21:41.984 08/22/07 Sev=Info/4 IPSEC/0x63700014
Deleted all keys
149 18:21:41.984 08/22/07 Sev=Info/4 IPSEC/0x63700014
Deleted all keys
150 18:21:41.984 08/22/07 Sev=Info/4 IPSEC/0x63700014
Deleted all keys
151 18:21:41.984 08/22/07 Sev=Info/4 IPSEC/0x6370000A
IPSec driver successfully stopped
