IP Phone Registration within VRF
Sep 5th, 2007
I am having issues getting IP phones to register within a VRF. The phone registration sequence continuously loops at Configuring CM List.
When i remove the voice vlan from the VRF the IP phone will register as normal
Has anyone seen this type of registration failure previously ?
Anonymous (not verified) Tue, 09/11/2007 - 10:04
Is this an SRST connection ? If so check whether you have configured the ip helper with this command " ip helper
