3005 Concnetrator group address pool, one address
Sep 5th, 2007
I want to set up a group for a single user to access our network.
I have an address pool configured globally and want to add this one single address in the same subnet, but ouside the existing pool.
The group will let me configure the pool, but a minimum of two addresses in the pool.
How do I configure a single address?
I tried the starting and ending range as the same address, but I get an error.
When I try to add starting ending
It will let me.
How can I have just as my address?
ivillegas Tue, 09/11/2007 - 10:05
You need to have more than one[ateleast two] ip address per pool.
johnd2310 Wed, 09/12/2007 - 14:34
As mentioned before me, you need at least 2 addresses in the pool even if assigning to 1 client. This is because the vpn conentrator itself will need an ip address.
