E1 connection between router 3745 and siemens central
Sep 5th, 2007
i have customer need to make E1 connection between siemens pbx and 3745 router
so i need the part number for the module i need on router 3745 and on the siemens central it self and i need to know if there any considration i must know
i hope any one answer me as fast as he can
Paolo Bevilacqua Wed, 09/05/2007 - 12:35
For the router, you need VWIC-1MFT-E1 or VWIC2-MFT-E1/T1 and AIM-VOICE-30.
For the PBX, ask siemens.
Then the constrains depends on what you are trying to do.
mostafamossad Wed, 09/05/2007 - 22:15
thank u for helping but i need to know what is the function of the AIM-VOICE-30 and why i need it
Paolo Bevilacqua Thu, 09/06/2007 - 00:23
It's a DSP, that is the hardware that converts voice into IP packets and vice-versa.
As an appreciation to those providing answers, please rate useful posts using the scrollbox below!
t.silva Thu, 09/06/2007 - 05:07
The AIM-VOICE-30 has a limited support for high-complexity voice codecs (G.729, G.723.1 etc). It support up to 16 concurrent calls that use these codecs.
If you need full support - 30 calls for E1 or 24 calls for T1 - you will need a NM-HDV or a NM-HDV2 module.
Take a look at these URLs to mount your solution: http://www.cisco.com/en/US/products/hw/routers/ps259/products_tech_note09186a00800e73f6.shtml
Paolo Bevilacqua Thu, 09/06/2007 - 05:23
True, but you can install two modules if needing 30 high-complexity calls.
For complete information there is to say however that some user were disappointed with the features of the AIM-VOICE-30, so the NM-HDV2 with PVDM2 can be a better choice as it uses newer DSP technology.
