ospf routing problems
Sep 5th, 2007
hi,
I have a problem when I'm using simulation software to run ospf configuration test. I only able to receive reply between 3 routers by using ping command (i.e R5 to R3). ps. all is in area 0.
How to configure the routers in order to receive reply from any destination when I using ping command from any source.
ospf setting as below
R1 network 192.168.1.1 0.0.0.0 area 0
network 192.168.1.33 0.0.0.0 area 0
R2 network 192.168.1.2 0.0.0.0 area 0
network 192.168.1.5 0.0.0.0 area 0
R3 network 192.168.1.6 0.0.0.0 area 0
network 192.168.1.9 0.0.0.0 area 0
network 192.168.1.49 0.0.0.0 area 0
and same for R4 and R5
thanks
Overall Rating: 5 (2 ratings)
Joseph W. Doherty Wed, 09/05/2007 - 09:52
You use just one network statment on all your routers:
network 192.168.1.0 0.0.0.255 area 0
PS:
Hosts have correct gateways?
devang_etcom Wed, 09/05/2007 - 10:50
  • Gold, 750 points or more
do one thing... if you have your all router in area 0 then configure following command on all router under OSPF process
network 0.0.0.0 0.0.0.0 area 0
regards
Devang
erichiew Mon, 09/10/2007 - 09:12
hi,
I tested both suggestions, but it still same. Because I'm new to this routing protocol, I want to confirm with yours that whether all routes will show equal numbers of path when using "show ip route" ? I also get same result as above when using lesses routers. But these problems wouldn't happen when using eigrp routing protocol. So what are the possible errors in my configuration? Which is the best way to design such network ?
Joseph W. Doherty Mon, 09/10/2007 - 14:46
Do all the router interfaces have the same OSPF cost metric?
