STP pvlan load-balancing
Sep 5th, 2007
All, I am trying to implement STP load balancing from shop floor to core network.
vlan 13 (voice) over 54 wlan bridging link
all other vlans (data) over terascope links
Could you guys confirm attached topology (viso)
Jon Marshall Wed, 09/05/2007 - 11:57
Apologies but can't read the detail in jpeg so will have a look at it when i get into work tomorrow.
Couple of things. Are you treating both uplinks as trunks ? and how are you going to ensure vlan 13 goes across 54MBps link. One thing you could try is to not allow vlan 13 on 155 trunk link and then gave the 54Mb link endpoints just be part of vlan 13.
I don't want to suggest too much though at moment as i really need to see diagram properly.
paul driver Wed, 09/05/2007 - 12:10
yes the uplinks are trunks and to ensure traffic for 54mb(voice) and 150 mb (data).
using stp vlan costs;
eg: vlan13 voice.
data links: spanning-tree vlan 13 cost 200
voice links: spanning-tree vlan 1, 10-12, 131,238 cost 200
