Need Site to Site example with both sides hiding ip's
Patrick.Beaven
Does anyone have a few examples of site to site vpns setup where you need to hide the private ip subnets on both sites. I cant find any good examples using static nat statement etc.
jvanwa1
Pat,
Here is what I have on my PIX 6.3 going to a customer's Checkpoint. Right now I am the only one able to start up the IPSec VPN tunnel; don't know if I need to change something or they do, so they can initiate the tunnel.
static (inside,outside) 64.233.169.99 192.168.111.1 netmask 255.255.255.255 0 0
access-list onion permit ip host 64.233.169.99 host 71.18.55.123
access-list onion permit ip host 64.233.169.99 host 71.18.55.127
crypto ipsec transform-set cheese esp-3des esp-sha-hmac
crypto map hotdog 30 ipsec-isakmp
crypto map hotdog 30 match address onion
crypto map hotdog 30 set peer 71.18.55.4
crypto map hotdog 30 set transform-set cheese
crypto map hotdog interface outside
isakmp key ********** address 71.18.55.4 netmask 255.255.255.255 no-xauth no-config-mode
isakmp identity address
isakmp keepalive 10
isakmp nat-traversal 20
isakmp policy 10 authentication pre-share
isakmp policy 10 encryption 3des
isakmp policy 10 hash sha
isakmp policy 10 group 2
isakmp policy 10 lifetime 86400
This is very Close to what i ended up doinng!
Pat
