numbered ACL's
Sep 5th, 2007
I have been working with named (I believe they are called "extended acls"??) for the past few years - I just began working on a router that is using numbered acls - I thought numbered acls did not offer the flexibility to edit them line by liine, I seem to remember having to remove the acl and reapply it? Is this true or is my memory faulty?
2801 router / IOS 12.4
szahid Wed, 09/05/2007 - 13:16
Dan :
Numbered ACLs can be edited just like named ACLs .
here is an example from a 2801 router.
D-R2801-13A(config)#ip access-list extended 100
Ext Access List configuration commands:
<1-2147483647> Sequence Number
default Set a command to its defaults
deny Specify packets to reject
dynamic Specify a DYNAMIC list of PERMITs or DENYs
evaluate Evaluate an access list
exit Exit from access-list configuration mode
no Negate a command or set its defaults
permit Specify packets to forward
remark Access list entry comment
Salman .
dan.tesch Wed, 09/05/2007 - 13:26
Thanks, in the past were there limitations with numbered acls? why would someone use one or the other or simply preference?
mohammedmahmoud Thu, 09/06/2007 - 01:40
Hi Dan,
Yes formerly numbered ACL couldn't be edited, but in the recent codes, you can edit a numbered ACL the same as named ACL, using this or that is simply preference like you've said.
Mohammed Mahmoud.
