Dude with configuration of GRE
Sep 5th, 2007
Hello!, I'm forming a GRE to handle IPX
into VPN. My interface serial 2 is connected to V.35 cable and the other point is db60 and it is connected to modem.
My server requires other applications from my local network. My gre configuration is:
int tunnel 0
ip add ip_address
tunnel source f0/0
tunnel destination ip_address
ip tcp adjust-mss 1436
keepalive 5 4
My question is I must to connect the fast of my router inside the fast of my server for configure my gre? or I can to connect my S0/2 like tunnel source s0/2?
paolo bevilacqua Wed, 09/05/2007 - 14:07
  • Hall of Fame,
    Founding Member
Hola,
As tunnel source you should use an interface which address is reachable and pingable from the other router. If both serial and FE are, both will work.
