Allowing TRACEROUTE through PIX
Sep 5th, 2007
What is required to allow a traceroute to go through the PIX firewall? I believe I have it setup correctly, but I'm still unable to trace through. It just times out when it gets to the firewall. Thanks.
cewhitnel Wed, 09/05/2007 - 14:38
Use this ACL applied to your outside interface.
access-list "ACLNAME" permit icmp any any time-exceeded
corey.mckinney Wed, 09/05/2007 - 15:11
How do I apply that ACL to the interface? I can't find the command.
mkkeyan Thu, 09/06/2007 - 03:31
access-group "access list name" in interface outside
Just add the following to your outside interface:
access-list permit icmp any any echo-reply
access-list permit icmp any any unreachable
access-list permit icmp any any time-exceeded
access-group in interface outside
** can be anything you want for the outside interface**
save with write mem and also issue claer xlate
pls rate posts if it helps.
