09-05-2007 03:25 PM - last edited on 03-25-2019 07:37 PM by ciscomoderator
Can anyone post their UK CME dial plan? I am looking to setup our office in the UK but the UK Numbering Plan is so complicated, I was hoping to save some time by seeing if anyone already had it configured. I have seen the Cisco docs in reference to the full-blown CallManager Dial Plan for the UK Numbering Plan but was hoping that someone might have something already setup for CME.
Please advise. Thanks!
09-05-2007 08:37 PM
What about using 9T and sending everything that start with 9 to the PSTN?
The only drawback is that the users will have to wait for the inter digit timeout before the call will be sent out.
HTH, Avner
09-06-2007 01:40 AM
Aizhar -
Yeah I have that in play now. I am trying to avoid the inter digit timeout.
09-06-2007 12:58 AM
This is what I use, nice and simple :)
dial-peer voice 53 pots
description ** Outgoing national landline / mobiles **
destination-pattern 90..........
direct-inward-dial
port 0/1/0
forward-digits 11
no sip-register
09-06-2007 01:39 AM
Davieshuw -
Aren't UK numbers variable in length?
09-06-2007 02:08 AM
ah ok i see where your coming from.. there are short area codes, but they only apply if your IN the local area.
Basically our office is in Cardiff. Our area code is 02920. So if your outside of cardiff you'd dial 02920 487xxx for our office.
But if your local, ie in the cardiff area, then you dont have to dial the complete 02920, you just dial the cardiff local code which is 20 . so if your in our local area, you'd just dial 20 487xxx
Im pretty sure all other local area codes are 2 digit, heres what ive got to accomodate this:
dial-peer voice 54 pots
description ** Outgoing local cardiff number *
destination-pattern 920......
port 0/1/0
forward-digits 6
prefix 20
no sip-register
09-06-2007 03:07 AM
davieshuw -
Very helpful thanks. I was looking around the web yesterday and came across this post:
http://www.velocityreviews.com/forums/t235339-uk-dial-plan.html
Which led me to believe it may be a bit more complicated.
Do you take any of those other rules listed in that post into account or are the unnecessary?
09-06-2007 03:22 AM
I can see how that post could complicate things :) We're fairly relaxed in our office so we dont really need much control over dialled numbers. The destination-pattern 90.......... forward-digits 11 is going be fine for national calls and calls to mobiles.
BT (UK telco) have tried to complicate things, but just remember the majority of area codes are 5 digit.
Using the above pattern we're going to be fine dialling 01215 xxxxxx (Birmingham) 02920 xxxxxx (Cardiff) 07786 xxxxxx (typical mobile number)
The only other one you may need is :
dial-peer voice 51 pots
description ** Emergency dial-peer **
preference 1
destination-pattern 999
port 0/1/0
forward-digits 3
no sip-register
09-06-2007 03:57 AM
Do you bother with the 112 for Police?
09-06-2007 04:05 AM
no we just use 999, you go through to an operator who asks what emergency service you require. They answer in like 2 seconds anyway.
09-13-2007 09:47 AM
Davieshaw -
How do you handle Free Phone and National Local numbers as these seem to be variable in length?
Your help is greatly appreciated.
Mike
09-18-2007 11:35 AM
Can anyone answer this one?
