Deleting a virtual interface
Answered Question
Sep 5th, 2007
There is a debate among our engineers on the proper command to delete a virtual interface on an MSFC. Which command is correct and why?
delete interface vlanxxx
or
no interface vlanxxx
There's a dinner riding on this one!
1 vote
Correct Answer by Pavel Bykov about 9 years 4 months ago
delete interface ??
Never heard of it. DELETE command is an EXEC command used for file system operation (e.g. delete a certain file) but certainly not deleting interfaces.
I checked all of our 3560,3750,c6506-native, and c6506-hybrid with MSFC. All results are negative. Like this:
msfc_hra_old(config)#del?
% Unrecognized command
c6506_hra_1(config)#del?
And so on.
That's what I expected btw, because again, I have never heard of the command.
There is a command that is called "DEFAULT" maybe that's the one you are thinking of. This command returns an interface to a default state.
NO INTERFACE command deletes a virtual interface.
When reenabling virtual interface (not SVI) some configuration may reappear. Therefore the cleanest way to delete a virtual interface is:
default interface fa0/0.1
no interface fa0/0.1
SVI could be deleted using "no" command without the need to use "default" command.
As to your question. IF the command does exist on some special version of IOS, it surely doesn't exist anywhere else. Therefore using a special command, that is not documented is not a good idea in an routine environment.
Overall Rating: 5 (2 ratings)
Edison Ortiz Wed, 09/05/2007 - 20:37
The latter
Rack1SW2#show ip int bri | ex una
Vlan28 183.1.28.8 YES manual up up
Rack1SW2(config)#no interface vlan 28
Rack1SW2(config)#do show ip int bri | ex una
peter.mark Thu, 09/06/2007 - 04:33
Is there a reason why the delete interface command should not be used?
Correct Answer
Pavel Bykov Thu, 09/06/2007 - 08:51
delete interface ??
And so on.
peter.mark Thu, 09/06/2007 - 09:26
Your correct. I meant to say default.
Thank you for clearing this up.
