Unity-Exchange, can I combine HDD partition?
Sep 5th, 2007
I have HP server to build exchange off box with 4EA HDD(72G each). RAID1 for 1st two(slot 0/1) and 2nd two(slot 2/3). the partition is C and D from 1st set and E from 2nd set. the requirement is more than 72G for exchange voice mail box. Can I combine D and E into single partition to make about 130G?
Thanks in advance,
Ginger Dillon Tue, 09/11/2007 - 15:17
  • Blue, 1500 points or more
Hi -
How many users are you planning to support for this off-box Exchange server? Is this for Windows 2003 SP2, Exchange 2003? I would recommend 20Gig just for the OS partition. To be honest, this really is not the best practice configuration for an Exchange server. I included a link for your review -
http://searchexchange.techtarget.com/tip/0,289483,sid43_gci1195222,00.html. You cannot combine 2 physical disks from separate logical volumes together. Your C:D: is two physical volumes (1 logical volume). Same for the E set. I would consider purchasing additional disk drives to either create a Raid5 set OR Raid10 set for the Exchange information stores.
Ginger
