CME 3.3 http issue
Sep 5th, 2007
We are running CME 3.3 and have issues regarding setting up extensions and phones using the HTTP browser. If we try to assign a button to the phone then click ok and save we just get errors on page in the internet explorer.
is this a java issue, if so what java should we use?
smahbub Wed, 09/12/2007 - 06:17
The ip http server command must be enabled on Cisco CallManager Express. However, if only https (ip http secure-server) is enabled, this command does not work. Both commands must be enabled.
cmelbourne Tue, 09/18/2007 - 00:59
we have the below config in the ccme router.
ip http server
ip http authentication local
ip http timeout-policy idle 60 life 86400 requests 10000
ip http path flash:
