IPIPGW with the verizon IP trunking Service
Sep 6th, 2007
I was wondering if anyone has so example Dial-peer configuration for doing a IPIPGW. My customer is signed up using a IP Trunking service in a MPLS cloud with VzB. I registered the 3845 router with all the proper IOS and Lic into the CCM 4.2(3). The GW is setup to do H323 to SIP see config below. I will be running 700 sites off of two clusters and 2 IP to IP GW. Sites are small.
voice-card 0
dspfarm
dsp services dspfarm
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
h323
sip
bind control source-interface GigabitEthernet0/0
bind media source-interface GigabitEthernet0/0
rel1xx disable
voice class codec 1
codec preference 1 g729r8
description IPIPGW Link to 10.x.x.0 Network Cluster A
ip address 10.x.x.254 255.255.255.0
ip virtual-reassembly
load-interval 30
duplex full
speed 1000
media-type rj45
h323-gateway voip interface
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
media-type rj45
ip route 0.0.0.0 0.0.0.0 10.x.x.1
ip http server
no ip http secure-server
control-plane
voice-port 0/1/0
voice-port 0/1/1
voice-port 0/1/2
voice-port 0/1/3
sccp local GigabitEthernet0/0
sccp ccm 10.x.x.x identifier 2 priority 2 version 4.1
sccp ccm 10.x.x.x identifier 1 priority 1 version 4.1
sccp
sccp ccm group 1
associate ccm 1 priority 1
associate ccm 2 priority 2
associate profile 1 register DC1MTPIPIPGW
dspfarm profile 1 mtp
description MTP for IPIPGW Data Center 1
codec g711ulaw
maximum sessions software 250
associate application SCCP
dial-peer voice 100 voip
description voip dial peer - To Verizon IP Trunk
destination-pattern .T
rtp payload-type cisco-codec-fax-ack 114
rtp payload-type cisco-codec-fax-ind 113
voice-class codec 1
session protocol sipv2
session target sip-server
incoming called-number .
dtmf-relay rtp-nte digit-drop
dial-peer voice 101 voip
description voip dial peer - Inbound to CCM SUB1 CLA
preference 2
session target ipv4:10.195.32.3
dtmf-relay h245-alphanumeric
dial-peer voice 102 voip
description voip dial peer - Inbound to CCM SUB2 CLB
preference 3
session target ipv4:10.195.16.4
dial-peer voice 201 voip
description voip dial peer - Inbound to CCM SUB1 CLB
preference 4
session target ipv4:10.195.16.3
dial-peer voice 202 voip
description voip dial peer - Inbound to CCM SUB2 CLA
preference 5
session target ipv4:10.195.32.4
gateway
timer receive-rtp 1200
sip-ua
retry invite 2
retry bye 2
retry cancel 2
retry options 1
sip-server dns:abcxyz.com
g729-annexb override
gatekeeper
shutdown
jposada_us Mon, 09/10/2007 - 08:33
dconstantino, are you asking for a dial-peer example because you are geeting problems for calling to the IP Trunk or just to have an example and compare your configuration? I sew yur configuration and look fine.
I have exactly the same configuration as you have, CCM 4.1(3) with 2801 IPIPGW IOS 12.4(6)T7 and a SIP trunk to a carrier, The IPIPGW is doing interworking between H323 & SIP and it's working fine.
Maybe what is missing is the "h323-gateway voip bind srcaddr 10.x.x.254" line under the interface GigabitEthernet0/0, the "bind interface" under the sccp ccm group 1
Here is mi dial peer to the PSTN via the SIP IP trnunk to the carrier. MTP is enable for calling to PSTN
dial-peer voice 1009 voip
description dial peer to PSTN
session target ipv4:sip-server
dtmf-relay rtp-nte
codec g729r8 bytes 30
fax rate 9600
ip qos dscp cs3 media
ip qos dscp cs3 signaling
I hope it can help you.
Aaron Dhiman Wed, 11/07/2007 - 07:40
So, is this really working with G.729 as your config suggests? Do you have G.711/H.323 from CM to the IPIPGW, then G.729/SIP to the carrier?
I thought that was not supported? Does it just require the latest DSPs (C5510s)?
dconstantino Wed, 11/07/2007 - 13:14
end to end G729
No DSP required because it is just IP to IP GW
You have to have a special IOS Cisco sends you a disk and Lic.
Then you confogure Enhanced IOS MTP's in CCM
And setup the SCCP and CCM groups on your IPIPGW
jposada_us Wed, 11/07/2007 - 20:37
What you mean when you said "No DSP requiered"?
I believe for enhaced IOS MTP you do need DSP resources.
can you confirm that please?
dconstantino Thu, 11/08/2007 - 05:07
This is an IP to IP Gateway all it dose depending on how you set it up H323 to SIP,SIP to SIP, or H323 to H323 it is a passthourgh for the RTP stream.
The IOS MTP is software. look at my configuration.
The only reason I have DSP on this router because It use to run TDM voice (PRI) on it and I converted it to a IPIPGW.
You do not need DSP to route data traffic all you are doing is routing IP traffic and then the service provided sends it out to the PSTN.
http://www.cisco.com/en/US/partner/products/sw/voicesw/ps5640/products_configuration_guide_book09186a0080409b6d.html
Read this Doc
I have 15 pilots om two IPIPGW and starting my main rollout in Dec. 800 sites two CCM clusters.
Aaron Dhiman Thu, 11/08/2007 - 07:01
So you are using only the CM IOS Enhanced Software MTP with this? This is all VERY interesting. I was on an engagement a while ago where the Cisco solution lost out due to lack of ability to trunk to VZB via G.729 with SIP. Only G.711 was supported. So, not it seems, G.729 is finally supported!
Your initial configuration was for G.711 MTP only, though. Could you post your final config?
jposada_us Thu, 11/08/2007 - 15:13
I understand. you are doing passthrough for te RTP, the IPIPGW does not join any rtp traffic.
The reason i ask you is because I have a similar configuration, an ipipgw doing interworking between sip/h.323 but have to perform SBC functions since i have the customer network talking to the ISP network. so the ipipgw join all rtp streams.
