route-map on 3560g
Sep 6th, 2007
I am trying to isolate a vlan interface in order to dedicate it for management.
I tried to isolate it (at layer 3) using route-map :
my admin net is 1.0.0.0/24 (int vlan 945)
my operation net is 2.0.0.0/24 (int vlan 8)
ip access-list standard allow_1_0_0_0
permit 1.0.0.0 0.0.0.255
deny any
exit
ip access-list standard allow_all
permit any
exit
route-map deny_routing_to_1_0_0_0 deny
match ip address allow_1_0_0_0
set interface Null 0
exit
route-map deny_routing_to_anywhere deny
match ip address allow_all
exit
int Vlan945
ip address 1.0.0.2 255.255.255.0
ip policy route-map deny_routing_to_anywhere
int Vlan8
ip address 2.0.0.2 255.255.255.0
ip policy route-map deny_routing_to_1_0_0_0
It seems pretty clean to me (cleaner than using ACLs ?), put the problem is that "set interface 0" is not supported on the 3560g.
I tried using a loopback with an ip in the range 127.0.0.0, and using set ip next-hop but that's not possible either.
Is it possible to do what I am tring to do without using ACLs directly in an vlan interface ?
Best regards
Guillaume
cvf-reg2cis Thu, 09/06/2007 - 06:03
Thanks Mohammed.
Indeed, I did configure "sdm prefer routing".
But it did not solve my question.
Guillaume
mohammedmahmoud Thu, 09/06/2007 - 06:08
  • Green, 3000 points or more
hi Guillaume,
After configuring it, you need to reload the switch.
HTH,
Mohammed Mahmoud.
cvf-reg2cis Thu, 09/06/2007 - 06:32
Thanks Mohammed, I already did reboot the switch after inputing the command.
#sh sdm prefer
The current template is "desktop routing" template.
The selected template optimizes the resources in
the switch to support this level of features for
8 routed interfaces and 1024 VLANs.
number of unicast mac addresses: 3K
number of IPv4 IGMP groups + multicast routes: 1K
number of IPv4 unicast routes: 11K
number of directly-connected IPv4 hosts: 3K
number of indirect IPv4 routes: 8K
number of IPv4 policy based routing aces: 512
number of IPv4/MAC qos aces: 512
number of IPv4/MAC security aces: 1K
Guillaume
