IGX-Card showing ACTIVE-F status
Sep 6th, 2007
As this happens due to errors or link fluctuation , how can we solve this problem of reseting card everytime.Is there any solution for that?
Overall Rating: 3.5 (2 ratings)
bwilmoth Wed, 09/12/2007 - 08:32
you do not need to actually reset the card to clear the failure you are encountering. Since you have a background test failure, you need to issue "resetcd f" (where is the slot). This will not reset the card, but will clear the failure.
rajput_p Thu, 09/13/2007 - 09:17
Also you can try to upgrade the firmware hope this will work. If not then you have simply run this command resetcd -f. This will not reset your card but clear all the failure or alarm
