Traffic progress through pix
Answered Question
Sep 6th, 2007
My question is can the pix send traffic out through the same interface it received the traffic on? I'm currently using pix os version 6.2.
Dan
Correct Answer by whisperwind about 9 years 6 months ago
No Dan not with that version of PIX OS, you need to upgrade to the 7.x or 8.x and also note that you may need more memory to accomplish when you upgrade you want to enable the command:
CYPHER(config)# Same-security-traffic permit ?
configure mode commands/options:
inter-interface Permit communication between different interfaces with the
same security level
intra-interface Permit communication between peers connected to the same
interface
Overall Rating: 5 (2 ratings)
Correct Answer
whisperwind Thu, 09/06/2007 - 07:28
same security level
interface
hsajwan Thu, 09/06/2007 - 09:47
I would like to add something here....Not every 7.x code has this functionality. U-turning of traffic is allowed only from 7.2.1 onwards.
