Problem in applying QOS on PRI channel Group
Answered Question
Sep 6th, 2007
HI,
I am having a WAN connection between 2 sites A&B. ON A side we are using a private/leased line of 768k and on B side we are using 12 channels of a PRI line.
When I am applying QOS on the A side eveything is fine and in the the output of command "sh int s0/0" it is showing available bandwidth is equal to 75% of 768K.
But on B side when i have applied Qos it is showing me the available bandwidth is 3kb.
After removing QOS on the channel-group int it is showing me 768k of avaible bandwidth in "sh int s1/0:1".
I have attached all the outputs in the attachment.
Waiting for the replies.
Mahi
Correct Answer by mheusing about 9 years 6 months ago
Hi Mahi,
The attached policy is
policy-map mahi
class QPM_Q6
bandwidth percent 4
random-detect
class QPM_Q5_1
priority 230
class QPM_Q3
bandwidth percent 35
random-detect
class QPM_Q1
bandwidth percent 1
random-detect
class class-default
bandwidth percent 30
random-detect
The formula to consider is:
Available Bandwidth = max-reserv x interface bandwidth - allocated bandwidth
In your case:
interface bandwidth = 768 kb
max-reserv = 100%
allocated bandwidth = 230 kbps + 30 kbps (4%) + 268 kbps (35%) + 7 kb (1%) + 230 kbps (30%) = 765 kbps
Thus remaining bandwidth is 3 kbps. Nothing wrong with it. Router can do the math.
Regards, Martin
Overall Rating: 5 (2 ratings)
Correct Answer
mheusing Thu, 09/06/2007 - 07:36
  • Cisco Employee,
Hi Mahi,
policy-map mahi
class QPM_Q6
bandwidth percent 4
random-detect
class QPM_Q5_1
priority 230
class QPM_Q3
random-detect
class QPM_Q1
bandwidth percent 1
random-detect
class class-default
random-detect
In your case:
max-reserv = 100%
Regards, Martin
mohindersingh Thu, 09/06/2007 - 08:13
Hi Martin,
We are using same kind of QOS policy on other channel group interfcae also. ALL interfaces are configured with "max-reserved bandwidth command" as well as 100% distribution of bandwidth in QOS classes but they are showing half of the bandwidth as avaible bandwidth.
Can you clarify my doubt.
Thanks for ur reply.
Mahi
mheusing Thu, 09/06/2007 - 23:01
  • Cisco Employee,
Hi Mahi,
Can you provide the configs and respective show command output? Without this it is hard to state anything.
Regards, Martin
