cme basic software prob
Answered Question
Sep 6th, 2007
c1700-advsecurityk9-mz.124-11.T1.bin
cme-basic-3.3.0.3a.tar
cme-gui-3.4.0.0.tar
i have the above files installed on my 1700 router and i cannot make the cme run at all.
i cant see the below commands on the config mode
telephony-service
dn
ephone-dn
etc.
iam a newbie on this. pls advise. How can i enable the cme software in here.
also the gui is not working..the http://10.1.1.1/admin_user.html is coming garbled.
thansk
Correct Answer by paolo bevilacqua about 9 years 10 months ago
You are using the wrong image. You need one that has "voice" in the filename.
After that your CME will be 4.0 and if you want the GUI as well (technically is no needed) you need to load the corresponding files, the one you indicated are for older CME.
Note, you may find that default memory on your 1700 is not enough for voice image, so be prepared to order an upgrade.
Hope this helps, please rate if it does!
Overall Rating: 4 (1 ratings)
Correct Answer
paolo bevilacqua Thu, 09/06/2007 - 08:09
  • Hall of Fame,
    Founding Member
