creating internet access from ASA
Sep 6th, 2007
Hi all, if I want to use PAT for my inside clients to access the internet how do I do this on my asa, do I create a static nat rule, then add the LAN as my source network, then in translated, use the outside interface, do I need to use the PAT option at the bottom, or do I leave that ?
Jens Becker Mon, 09/17/2007 - 22:01
Here is an example for configuring PAT:
(config)# global (outside) 1 interface
(=> binds your external IP (from Interface "outside"))
(config)# nat (inside) 1 0.0.0.0 0.0.0.0
(=> configures NAT on the "inside" interface)
